Thanks for all the feedback so far!
Originally Posted by JesseK
Yet by far the biggest concern is the amount of side loading/twisting those swerve mount plates will go through with 140lbs of momentum running around on a field. Is there no way to add a second plate to support the top of the Revolution swerve module column?
Thanks for pointing this out. Originally we had one mounting plate that connected the swerve modules and the other plates. However, I didn't want to make the mounting plates without using CNC, and with our limited CNC ability, I thought it would just be easier to use the revolution mounting system. Thankfully we just got a sponsor with greater CNC ability so we'll look into that. How thick would you recomend making the mounting plate? 3/16 in or 1/4 in?
Regarding the gearing, we are using Toughbox Mini's with the 10:71 Gear reduction because they are going to come in the 2013 KOP. Along with the additional 2.25:1 reduction with the modules, with 4 in wheels its a little difficult to get a good gear ratio. As of now we have the reduction from gearbox to module at 1:2.4 letting our top speed without losses to be 8 fps. Is this fast enough? Or should we make it a bit faster?
Originally Posted by Joyride_67_1902
I can't find the post but I noticed that your pulley in the middle has the belt on both sides. Your not always guaranteed to line up. Art IV had a good picture explaining it but I can't seem to find it.
Thanks for pointing this out. We'll try and adjust our design accordingly.
Thanks, we'll post a revised edition later.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
