Go to Post No FIRST event is complete without Darude's Sandstorm. - sonichammer7476 [more]
Unread 10-10-2012, 08:30
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: Jaguar/Victor screw supplier
I would like to add that I would prefer binding head screws in this application if I was placing an order. All screws are not created equal.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-10-2012, 20:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I would recommend removing every single painted screw and throwing them in the garbage. There are markings on the motor controllers themselves, and those screws can and will get accidently swapped around. I know this from experience. If you rely on screw color you WILL eventually kill a motor controller. It's not a question of "if", just a question of "when".
Get people used to looking at the markings on the motor controller. If you have trouble seeing them, paint those, not the screws. You'll be happy you did in the long run.
Unread 11-10-2012, 15:06
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Doing this on a gray Jaguar leaves metal debris inside the unit. Not good. The effect is the same for a Victor (I believe) except the Victor is conformally coated so that the debris is typically left largely trapped in the coating itself (the coating wicks up the terminals).
What I encourage my team to do with Black Jaguars is to only remove and replace one screw at a time (if they need to remove a screw). If they're disciplined in this practice, the screw colors can be of use. Of course I also encourage them to follow "Trust, but verify".
Unread 11-10-2012, 17:10
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
I recommend that you also check into the finish of the screws that you will be getting. Certain finishes can create conductive particles, which can contribute to arcing across the terminals of your Victor or Jaguar.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Unread 11-10-2012, 11:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Al or Bruce -- do button head socket cap screw perform similarly to binding head screws? I agree with Bruce that it is easier to control the screw torque using a Torx head driver. The CAD view available on McMaster appear to show similar holding surfaces (under the head) for both types.
Richard Wallace
since 2003
