Go to Post Traction is good but a good driver will always win over a good robot. - Mike Norton [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 25-10-2012, 01:18
brian.axelrod brian.axelrod is offline
FRC #0846
brian.axelrod is an unknown quantity at this point
Re: pic: 3928 Swerve Module
What bearings did you use around the CIMs? Are they roller bearings or ball bearings? Also, do you have a sleeve around the CIM, or are the bearings riding on the CIM?
Unread 25-10-2012, 02:13
Aren_Hill's Avatar
Build Nifty Things
Originally Posted by Joe.Quirk View Post
How do connect the steering gear to the mounting plate? I assume there is some thin bearing in between, but how did you retain it vertically? This is for sure one of the coolest things I've ever seen.
Between the steering gear and the mounting plate there are two .25" diameter semi circle grooves (one in each plate) with .25" diameter delrin balls running in them, essentially forming a "deep groove" thrust bearing that can also handle axial load. (This was borrowed from team 16 who has perfected this bearing and graciously answered all of my questions regarding it)
The bearing is then kept from coming apart by a set of white delrin sliders that go up over the mounting plate from the steering gear and retain it.
Around the CIM exists a ~.090" thick 4340 alloy steel sleeve (we went pretty hard as it was round 1 of this bearing concept). Riding on the sleeve are 12 r3 ball bearings (6 on each side) each riding on a 10-32 bolt.
The bearings also have a groove in the steel sleeve that is deeper than the outer race of the bearing providing an thrust surface to retain the wheel in the middle of the module.
A guy who likes robots.
