Go to Post How many FIRSTers would quit if they found it was bad for them? I think most FIRSTaholics are thirteen steppers ;) - phrontist [more]
Go Back   Chief Delphi > Technical > Motors
Unread 15-01-2003, 21:45
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Hint #1: Look carefully at the front of the Bosch motor, then examine the plastic motor retainer on the back of the stock Bosch gearbox. Notice the two round holes in the motor that fit over the two round pins on the gearbox, which prevent the motor from rotating when it is applying torque.
Hint #2: One the front and back of the Bosch motor, there are two ~1/4" square indentations, spaced 180 degrees apart. Seems like they are perfectly located for alignment/retention locks, doesn't it?
Hint #3: Take a look at how the hold-down strap for your car battery works.
We are also going for the dual-motor, dual-speed transmission, updating our design from last year. Throwing away the Bosch gearbox, and just using the motor directly into the transmission saves about 2 pounds per side of the robot.
-dave
Steal from the best, and then invent the rest!
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Drill Motor Mount Experence ROB at RAGE Motors 3 04-02-2003 22:57
Drill motor suggestions... team222badbrad Motors 5 27-01-2003 09:59
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
