Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 28-11-2012, 15:26
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Re: pic: Another concept study
Originally Posted by akoscielski3 View Post
You may want to consider making the macanum's slower. 13 FPS will not give you a lot of torque on the wheels that is needed to make your roboto strafe. In 2011 we used CIMple boxes on our 6inch mecanum's and we were unable to strafe. I may be wrong because I am not a Mecanum master or anything, but this is just from my experience.
When we run a simple Mecanum drivetrain we run at around 9 fps. This seems to be about as fast as you can go and still get maximum pushing force from the Mecanums.
Last year we ran at about 10.7 fps and had no trouble. With the traction wheels we don't need to worry about the Mecanum's lower pushing force so we can run faster.
This concept is at 13 fps but that doesn't mean we would ever build it that way. Our driver said he didn't go to full speed at 10.7 fps very often so faster than that would have be a need driven by the game.
Unread 28-11-2012, 19:01
Garret's Avatar
Garret Garret is offline
AKA: Garret Smalley
I love this design (and the detail in the model), but I cannot see how are you going to make the hollow round housing like that for the traction wheels? I am sure I am missing something but it looks like it is just machined from one solid block of aluminum.
7 Years of FRC
Unread 28-11-2012, 19:22
Yeah - that one is a bit messy. I have it designed as a tube with end plates welded on and then machined.
Unread 28-11-2012, 22:41
REVving up for a new season
FRC #2848 (All-sparks)
I would recommend changing the setup so that the pivot is on the traction wheel and not the mechanum. The reason is that you will see a large bending force on your pivot if you are in traction mode and you get pushed from the side. The distance from your traction wheel to the pivot will act as a moment arm and can reek havoc. Now you are using box tubing which has a great bending strength, but you are also using that same box tubing to house a gearbox, so even a slight bend can really foul up the works.
This is a lesson learned from experience on 148. Take a look at the differences in the drive train between 2010 and 2011.
Greg Needel│www.robogreg.com
