Go to Post Think, Write, Re-Think, Erase or Post - and Deal With it Either Way. - Chris Fultz [more]
Unread 01-12-2012, 23:25
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: pic: How many balls are in Team 68's robot?
The question is not how many balls are in 68's robot.
The REAL question is, how many of the balls in the robot can they score in one go, and for how many points? (And if you try to tell me that all of them are 3's, I'm going to say that you're bluffing--the wheel can't get up to speed quite that fast without spitting at least a couple for ones and twos, unless they can reverse it for a bit.)
Well, since you asked,
  • <start at the fender>
  • The first one will fall out with some shaking, so maybe 1 pt
  • If we tap the last ball gently out towards the key and run the rollers backwards to smash the fifth through eighth balls into the ground, we can probably get the 4th ball out of the shooter. The second and third balls could then pop out, with maybe enough force for 2 2pts
  • This is the tricky part. We'd have to turn off the shooter, and stack the remaining four balls just right (the robot was designed to not carry four in the tower)
  • <drive forward (farther away) to key, with robot centered directly over front edge of key>
  • Shoot one ball for 3 pts
  • <drive backward (closer) on key, leaving robot ~1/4th of the way on the key>
  • Shoot four balls for 4 3pts
  • <Retrieve final ball from somewhere between key and coop bridge, return to previous spot>
So there you have it. I counted 23 out of a possible 27 points, if all the shots go in.
Yes there are nine balls.
The fourth shot will go farther than the next four because putting four balls in compresses them together; decompressing the first ball in that stack would cause it to jump out a little.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
