Go to Post You people are online way too early in the morning... - Beth Sweet [more]
Unread 10-12-2012, 01:00
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Re: pic: Sheet Metal with VexPro parts
EDIT: Nevermind I realized you are not direct driving. If you have the answers though feel free to reply.
Looks really slick. Simple and will get the job done. One question I have as I am also looking into using the vexpro components on our drivetrain:
For the wheel that is direct driven from the gearbox, did you place the inner of the two Hex VersaHub towards the center of the robot from the inward-most sprocket?
The reason I am asking is that I was thinking about the alignment of the sprockets since in a setup like this only directly driven wheel needs the two Hex VersaHubs while the other two need the bearings which do not add to the "stack" of the VersaHubs and Sprockets.
Maybe a render of the direct-driven wheel would be easiest to understand. Also are you planning on machining the output hex shaft to a certain length to fit your design?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
