Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 11-12-2012, 18:27
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Ballistic trajectory with air friction drag and Magnus
Originally Posted by Michael Hill View Post
Hmm, perhaps you're right (capital D instead of lowercase D in CD). However, finding the correct constants aren't so trivial.
If I had a shooter that could launch a ball with the same (known) launch speed and launch angle with and without spin1, I would try the following:
Set um=0 and adjust ud to match the trajectory1 with no spin.
Leaving ud at that setting, adjust um to match the trajectory with the expected spin. (repeat to get um's for various spins if needed).
Then I'd launch the ball at various angles (and speeds) and see how well the simulations matched the actual trajectories1.
It would make an interesting science project.
1Probably need a high-speed frame-timestamped video camera to determine launch speed, angle, spin, and trajectory
