Go to Post I can't help but notice during the building sequence, there were a whole lot of student hands working on that robot. Just sayin'. - Taylor [more]
Unread 17-12-2012, 08:13
MentorPrice's Avatar
MentorPrice MentorPrice is offline
Mentor/FIRST Alumni/Engineer
AKA: Kevin Price
FRC #1708 (Amp'D Robotics)
MentorPrice is an unknown quantity at this point
Re: pic: New to CADing for FRC. Critique? Would this work?
Plasma cutters are nice to have especially being able to cut out certain parts of the body to reduce weight. Looking really good!
Unread 17-12-2012, 11:42
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Increase the diameter of the standoffs that hold the sides together. Doing so will distribute the shock load better and also provide more surface area to help stiffen the side plates when your assembly is tighten. If you added a bend along the leading edge that would help and you could add some brackets between the side plates to keep the plates parallel and square
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 17-12-2012, 14:52
mwibbels's Avatar
mwibbels mwibbels is offline
FRC #2122 (Team Tators)
mwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond reputemwibbels has a reputation beyond repute
In addition to the comments that have already been made. If I were reviewing the CAD with our guys - we would be looking to:
1. Use the members that join the left wheel module with the right wheel module to provide structure/support for the wheel modules themselves- you can see the cuts and joining holes in the 177 images that Akash posted. With a couple bends, like Roy mentioned, or a piece of angled aluminum joined to your side plates, you can tie into the cross tubes, and everything will stay a lot more solid and square.
2. Make the side plates as close together as possible while enabling chain maintenance.
3. Increase the number of standoffs between the plates - especially around the wheels as the side loading on the frame will be highest close to the wheel that is on the ground.
4. Either support the outboard end of axle out of the vexpro transmission or analyze its ability to withstand the cantilevered loading. I have not analyzed the vexpro transmission (so it may be fine in this application), but we generally avoid cantilevered drive members for our bot if we haven't analyzed or prototyped the system with the cantilevered loading.
In general - it is looking really neat - looking forward to seeing some images of the KleinBOTS' machine this year!
Unread 17-12-2012, 16:40
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
In addition to the many valuable recommendations already made, I'll add these things to check for (I don't know if you've already done some/all of these, just wanted to double-check):
- Make a 2D sketch (or 3D model, if you feel like it) of the chains/belts to ensure none of them hit your standoffs.
+ It looks like a couple of your standoffs may be in the way, but it's hard to tell, obviously
- Design for chain tensioning and/or use a chain length calculator
+ Could be a floating wheel, tensioned by a screw or turnbuckle
+ Could be a larger sprocket placed in the chain run (like 118)
+ Could be a small sprocket (or piece of delrin) pushed against the chain until tight
- I'm having a hard time judging the scale, but if you're pressing bearings into your sidewalls, ensure your holes are toleranced to get a good press fit (depends a lot on machining method used... I'm unfamiliar with the plasma cutter)
- Standoffs can be a lightweight way to make a more rigid structure between two sheet metal plates... I would recommend at least using some pretty large OD standoffs and potentially putting a couple plates across that have two holes in each sidewall. This should add significant rigidity
- Also, you do want to ensure that your drive modules mount to the rest of your frame rigidly and without creating stress-concentrated areas...
What thickness of aluminum do you have modeled so far? With a better-optimized lightening pattern and good structural design I would say you don't need anything thicker than .125; however, I don't have any experience with flangeless sheet metal drivetrains.
Best of luck in your design!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 17-12-2012, 17:28
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
clandry94 is an unknown quantity at this point
Thank you everyone for the support and tips. We will take them into consideration.
To Nathan: I modeled for .125in sheet metal.
I have another question as well:
-What works better, bearings in the sidewalls or on the wheels themselves?
-Is there any mathematical method to determining where to cut out for lightening while providing support to the structure at the same time?
