Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 17-12-2012, 14:19
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: Sheet Metal with VexPro parts
Here's an okay look at what I roughed in for chain tensioning on the end wheel sets.
The white parts on the right side are part of the tensioning system. One is a U-shaped bracket that straddles the wheel and captures the axle in two places. The axle continues through that part and into the blue frame pieces where it can slide in a slot. The black pieces are acetal disks that act as spacers and as thrust washers and should help to spread side-loading out over a larger area than a typical washer or the bolt head.
The bracket also has a captive nut installed. Threading a bolt into that nut will pull on the wheel and tension the chain. The second, right-most white part is the fixed plate the bolt pulls against; it could just as easily use the blue, outer drive train cross member, but I wanted to avoid having the bolt head stick out into where the bumpers will sit and it also makes it possible to assemble each side of the drivetrain as a 'pod' without putting together the entire frame first.
--Madison--
...down at the Ozdust!
