Go to Post Dang. There goes the hint that was supposed to go out next week. Gotta start over now.. - dlavery [more]
Unread 17-12-2012, 16:40
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: pic: New to CADing for FRC. Critique? Would this work?
In addition to the many valuable recommendations already made, I'll add these things to check for (I don't know if you've already done some/all of these, just wanted to double-check):
- Make a 2D sketch (or 3D model, if you feel like it) of the chains/belts to ensure none of them hit your standoffs.
+ It looks like a couple of your standoffs may be in the way, but it's hard to tell, obviously
- Design for chain tensioning and/or use a chain length calculator
+ Could be a floating wheel, tensioned by a screw or turnbuckle
+ Could be a larger sprocket placed in the chain run (like 118)
+ Could be a small sprocket (or piece of delrin) pushed against the chain until tight
- I'm having a hard time judging the scale, but if you're pressing bearings into your sidewalls, ensure your holes are toleranced to get a good press fit (depends a lot on machining method used... I'm unfamiliar with the plasma cutter)
- Standoffs can be a lightweight way to make a more rigid structure between two sheet metal plates... I would recommend at least using some pretty large OD standoffs and potentially putting a couple plates across that have two holes in each sidewall. This should add significant rigidity
- Also, you do want to ensure that your drive modules mount to the rest of your frame rigidly and without creating stress-concentrated areas...
What thickness of aluminum do you have modeled so far? With a better-optimized lightening pattern and good structural design I would say you don't need anything thicker than .125; however, I don't have any experience with flangeless sheet metal drivetrains.
Best of luck in your design!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 17-12-2012, 17:28
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
clandry94 is an unknown quantity at this point
Thank you everyone for the support and tips. We will take them into consideration.
To Nathan: I modeled for .125in sheet metal.
I have another question as well:
-What works better, bearings in the sidewalls or on the wheels themselves?
-Is there any mathematical method to determining where to cut out for lightening while providing support to the structure at the same time?
