Go to Post You move on because FIRST isn't about the penalty or the un-penalty or whose robot is agressive and who is timid. - Collin Fultz [more]
Unread 18-12-2012, 13:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Sheet Metal with VexPro parts
Originally Posted by roystur44 View Post
Consider flipping the u bracket the other way and pushing the bracket to create tension.
I typically focus on less tangible matters like software and electricity, so I might not be as qualified as others to comment on this, but I'll do it anyway.
I have noticed that pulling tends to enforce appropriate alignment, while pushing has a habit of bending things out of the desired line. In the case of this chain tensioning system, the bracket holding the axle won't have a lot to keep it from rotating if you just push on it. If the spot you're pushing on isn't actually aligned with the axle, it will be actively encouraged to rotate out of the way.
