Go to Post Force yourself now, today, to learn one new thing each day. When you lay down on your fluffy pillow at night, before you say your prayers, ask yourself if you have learned anything new. If the answer is "NO" then you better get up and find something. - Al Skierkiewicz [more]
Unread 19-12-2012, 16:21
Rob Stehlik's Avatar
FRC #0610 (Coyotes)
Re: pic: 2451 PWNAGE Off-season 2012
Very Cool! I love seeing design from your team since they are often outside the box and a real showcase of precision machining. What is the shaft made out of? What about the contact rings? After looking at the picture for a while, I understand why you would want to use two brush assemblies, but the color coding on your wires is a bit misleading, no? Would it be possible to separate the brush holder from the PCB and just use one per ring, reducing the number of CIMs you would have to sacrifice?
I can't wait to see the rest of the swerve.
Rob
Unread 19-12-2012, 17:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Seems like a lot of weight and space allocation for an electrical connection.
Unread 19-12-2012, 18:37
Excellence is Bliss
FRC #0111 (WildStang)
If I understand the purpose of this component, it would remove the limit to how many times a swerve with CIMs built into the modules could rotate, which is one of the major pitfalls of that design. Since a coaxial swerve design tends to eat up machining resources, I think the ability to make a simpler swerve to complement this is a significant benefit to a team like 2451. To my knowledge, they have one major machining sponsor (Genesis Automation), and the time it would take for them to make the components for a coaxial swerve seems like it would be better spent machining other things.
Unread 19-12-2012, 18:40
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Very impressive. PWNAGE has quickly become a powerhouse team because they are able to produce stuff like this. I'm really looking forward to competing with them at Midwest this year!
You mentioned it was designed for a swerve module. Any plans to integrate this into a full swerve drive?
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 19-12-2012, 19:15
I'm curious how FIRST would rule on the legality of this as it is being made from CIMs.
Unread 19-12-2012, 19:29
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Cool! This is the sort of cutting edge design stuff that you don't see often here on CD. It looks like this could end up being a lot more simple than a coaxial swerve, and it looks really well engineered. I really love the machining too.
If you do run this as part of a swerve, would the two radial bearings on the top and bottom of the shaft take the weight of the robot, or does this assembly go on top of other bearings that supported the robot? Also, any plans for integrating a steering motor into this assembly? Finally, if you want to put encoders on the drive motors, will there be some other slip ring assembly to get the signal out?
-Plutarch
Unread 20-12-2012, 02:49
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
This is a very risky investment of effort given the GDC's historic position on slip rings. They have been prohibited some years, and have been allowed other years only if they were COTS (commerical off the shelf.) Last year's [R44] stated:
"Branch circuits may include intermediate elements such as COTS connectors, splices, COTS flexible/rolling/sliding contacts, and COTS slip rings,..."
With the power distribution rules emphasis on the safe use of COTS components, I would say it is very unlikely that a home-made slip ring would be permitted, especially for high amperage motors circuits.
Also keep in mind the fabrication schedule rules such as last year's [R18]:
"Robot elements designed or created before the Kick-off presentation, including software, are not permitted. EXAMPLE: A team realizes that the transmission designed and built in the fall perfectly fits their need for a transmission to drive the Robot arm. They build an exact copy of the transmission from the original design plans and bolt it on the Robot. This would be prohibited, as the transmission - although fabricated during the competition season - was built from detailed designs developed prior to kickoff."
The example goes on to say that software that is developed prior to kick-off may be used if it is made generally available to other teams on a public forum. It becomes a COTS product because the software itself is the product. It does not say that the same is true for mechanical designs, although I know this has been a frequent topic. Perhaps someone knows if the Q&A Forum has made a crystal clear ruling on this.
Unread 20-12-2012, 17:09
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
The slip ring module was an off-season engineering exercise. While discussing the difference between the co-axial and distributed swerve modules, the limitation of rotation of the distributed swerve module was discussed. The question was asked if there was any device that could be used to allow the module to rotate freely.
For those that don’t know, a distributed swerve module has the motor integrated into the swerve wheel module and therefore the CIM motor rotates around the steering axis. This means the CIM motor power leads rotate around the steering axis as well and limit the rotation that the swerve module can rotate before the CIM power leads twist too much and do bad things. This is due to the winding of the power leads around the steering axis as the motor and wheel assembly rotates.
Our sponsor Genesis Automation, uses Mercotac rotary electrical unions on their automated machinery. These are liquid mercury filled devices that have no mechanical wear and allow an electrical connection through a rotating device. These are not rated for the amperage that a CIM motor can draw and mercury filled devices are no longer FIRST legal.
In researching the slip ring we asked the question about how much brush contact area we need to power a CIM. This led to the question about how much brush contact area the CIM has internal to the motor. So we disassembled a CIM motor and looked at the brushes. This led to the idea of using the CIM brush assembly in a slip ring module. We determined that using two CIM brush assemblies in the slip ring would double the brush surface area that the CIM uses. This led to the design of a slip ring module from available materials.
After building a prototype we wired it in series with a CIM on one of our practice bots drivetrains. We then pushed a heavy box around our practice field at a low motor speed using the power of that one CIM alone. This simulated a high current load on the brush/slip ring. The main concern was fusing the brush to the slip ring under such high current loading. Another concern was sending too much heat into the slip ring and melting the solder joint between the slip ring and power lead. The polycarbonate housing was selected to be an electrical insulator as well as allow us to see if there was arcing between the brush and slip ring.
Since the slip ring was not being rotated in our practice bot like it would in a swerve, we were able to concentrate the current flow at one position on the slip ring. After pushing the box around the field we disassembled the slip ring unit and found no noticeable wear or deposits. This proved the CIM slip ring is a viable solution to use on a distributed swerve module. This was a perfect engineering exercise and a great learning experience for our team. We knew this was a topic discussed in the past so we thought we should share our experience on Chief Delphi.
-Nick
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 20-12-2012, 17:39
pwnageNick's Avatar
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
The shaft is made out of G10-Garolite which is an insulator, and the contact rings are made out of Alloy 932 Bronze.
We agree that for it to be competition legal, we would have to change the coloring on the wire.
The module only weighs .75lbs and is L 3, W 4.5, H 5.
It would be mounted on a structural piece of frame and the shaft would be connected to the swerve module by a flexible hose.
-Nick
Unread 21-12-2012, 07:46
AKA: Big Al WFFA 2005
Nick,
I have to say this is an amazing assembly. Nice job to everyone involved. Unfortunately, the COTS rule (quoted above) on slip rings seems to take precedent. If team built slip ring assemblies were to be considered, this design surely would be on the top of my list as an allowed item! I like the dual brush assembly design. I doubt that you would experience any wear or deterioration with the use of just one brush per ring either. The CIM brush assembly wears mostly due to the commutator edges and arcing. Neither would be present in this design. Did you design the ring to be the same diameter as the CIM commutator or did you contour the brush to match the ring? Maximum brush contact with the ring is essential to keep resistance and heat to a minimum.
I see nothing that would flag this as contrary to electrical practice, it seems as if the team has thought of everything. Prior to the rule on COTS slip rings, I would have allowed this in and FRC robot.
Did you have to sacrifice CIM motors or were you able to find the brush assemblies as separate items? I would bet that further refinements could bring the cost and weight down as well. In this service, ball bearings are not needed unless you are using the bearing for other purposes. The rotational speed is low and the range of motion over it's lifetime is also very low. The brushes would naturally follow any runout in a simple sleeve bearing. I like the addition of the rotary encoder as well.
All in all a very well thought out design. Congratulations!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-12-2012, 17:26
jspatz1's Avatar
AKA: Jeff
In 2010 (prior to the current rule allowing COTS slip rings, and in the only year we had occasion to test the issue) slip rings were not mentioned in the rules, and any type of slip ring including COTS or home-made were disallowed by the Q&A forum. Prior to that they had been allowed by the Q&A Forum on several occasions, even though they were likewise not mentioned in the rules. Now that it is specified in the rules that they are allowed but must be COTS, it would seem that the issue is pretty clear cut, however there has been unpredictability on this issue with the Q&A Forum.
Unread 21-12-2012, 18:06
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Ignoring R 44, wouldn't R 49 come into place?
[R49]
Motors, servos, and electric solenoids used on the Robot shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the
motor to the Robot and actuated part.
B. The electrical input leads may be trimmed to length as necessary.
C. The locking pins on the window motors (PN 262100-3030 and 262100-3040) may be removed.
D. The connector housings on the window motors (PN 262100-3030 and 262100-3040) may be modified to
facilitate lead connections.
Modifying the CIM would be disallowed, and we can bet this rule is here to stay.
Regardless, nice engineering exercise.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-12-2012, 18:24
The rule concerns modifying motors used on the robot. While these parts come from a CIM, they are certainly not being used as a motor on the robot.
