Go to Post Obligatory warning: School comes first. If you have to choose between doing homework and going to a build season meeting, do the homework. - Billfred [more]
Unread 21-12-2012, 09:27
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: pic: 4183 Testbead Chassis
Looks very clean - great job doing some educational, practical off-season work... best earmark of an improving team, in my opinion!
I second those who have mentioned teams using wood drivebases... it can be done very well and can be significantly easier to fabricate. I recall 173 - at least on their 2007 robot - used a many-ply (9 or 11?) birch plywood of about 3/8".
I don't have any experience with wood drivebases personally; however, our team (especially in it's early days) tended make things way too beefy and heavy. I know Oak is surprisingly dense, so I recommend intelligently experimenting some with using thinner/smaller parts in lower-load areas (it's easy to use a heavier member than needed just because you use it elsewhere... we've done this with 80-20, when many components could be 1x1x1/16 box alum, which is half as heavy). Speed-holing can also provide some weight savings... although I have also seen teams over-speed-hole a critical points. All that to say, "Be careful of surprisingly heavy drivebases... a 6WD doesn't need to weigh >50 pounds without electronics."
Also, if you're looking to save weight, switching to #25 chains or timing belts can be a good way to do it. The larger your sprockets are compared to your wheel diameter, the less tension they're subject to... A small change I recommend with little/no cost is to make the longer chain runs between the center wheels and the end wheels #25 chain instead. With a >3.5" sprocket, I would be surprised to see a failure on that chain run, but even then you'd still have 4 or 5 driven wheels.
It looks like you're using a 3/8" bolt for your axle... which I like using for dead axles... although be careful not to over-tighten them! I would recommend you make sure it's a Grade 8 bolt, though. From our team's experience, a standard (Grade 5) bolt is unlikely to hold up in competition.
I would strongly recommend implementing now the stiffness modifications you expect to make... Drive Bases - particularly 4, 6, and 8WD ones - take a surprising amount of internal load. A particularly important degree of stiffness is bending along the diagonals (when viewed from above). Drive Bases with insufficient stiffness can make a 6WD base with plenty of "center drop" hop. It's important to have a sufficiently strong drive base if you're going to be testing and comparing different drive trains, so you can get useful experience with each.
Best of luck this year!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Last edited by Nathan Streeter : 21-12-2012 at 14:00. Reason: Grammatical stuff...
