Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 21-12-2012, 14:40
Re: pic: Another Team 691 Swerve Module
Originally Posted by Garret View Post
The tread is 1.5" thick on a custom wheel 3" wheel. The wheel can be swapped for a dead-axle 3" colson if I change the shaft from 5/8" to 1/2".
Any reason you can't run 3/8ths and use the COTS Colson hub? I'd be wary of using the super thin roller bearings in a drivetrain application.
