Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 25-12-2012, 18:39
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Battery Voltage in Robot Drivetrain Simulation and Modeling
Originally Posted by apalrd View Post
Since the use time was so short, we were trying to push the charge (and surface charge) as high as possible, as quickly before a match as possible (to reduce fade of the surface charge).
Did you run any minibot pole-climbing tests to compare climb times using a given battery fresh off the charger vs the same battery 10 minutes after coming off the charger?
