Go to Post Our robot-in-progress got set on the scale yesterday, It came to about 115 pounds. Then I walked up and took out the battery, and everyone relaxed some. - Alan Anderson [more]
Unread 27-12-2012, 00:37
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: paper: Battery Voltage in Robot Drivetrain Simulation and Modeling
First, the design distance ('Ref Distance' on the calculator) is used as the time it takes to accelerate to that distance from stopped. I don't include decel time, just accel time. You would still be moving when you reached that distance. I did not write the majority of the calculator, it's JVN's.
Second, Time to Distance. Time to Speed is used to validate acceleration targets, to make sure shorter-distance movements might possibly be acceptable.
Third, this method was the easiest method to implement. It has some noise, especially at the start, so I filter the voltage. It seemed to work well enough.
The reason I calculate it iteratively is because voltage is needed to calculate torque in the mechanical portion of the calculator. So, I calculate voltage from the last iteration current, for use to calculate this iteration's torque. The voltage change per iteration is so small that I don't really need immediate accuracy.
Kettering Motorsports
