Go to Post Maybe we can start a FIRST team on Mars. - Karibou [more]
Unread 29-12-2012, 20:57
Joey Milia's Avatar
FRC #0192 (GRT)
Re: pic: WCD
We had two 3/8 plates that fit halfway into pocketed tube and two bolts with spacers holding them together. Tensioning was done with a bolt from the end of the box beam to one of the two spacers. With the chain pulling one way and the tensioner pulling the other, the shaft ended up at a slight angle. It still ran fine and wan't much of a problem but it probably put additional load on the bearings.
For the season we machined one big spacer that pocketed into each plate and partially held the bearing on each side. Because both bearings where in once piece they stayed in line.
