Go to Post Our role models are practical visionaries. That's the glue. - JaneYoung [more]
Unread 31-12-2012, 00:58
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: pic: WCD
Originally Posted by the.miler View Post
Alternatively, you could make your bearing block out of a single piece of 1.25" wide by 2" high at 1/8" thickness tube, available at onlinemetals:
http://www.onlinemetals.com/merchant...269&top_cat=60
I know it's 6063 aluminum; our drivetrain was made with the stuff last year, and it was just fine to machine.
Bore your bearing hole and a couple of screw holes, and then lop off the top of your tube to make a C-channel like piece. Slide it onto the robot, tighten down your screws, and you're good. Our team used the system on previous robots before we moved away from the cantilevered drivetrain design; while I cannot personally attest to its effectiveness, as it was before my time, our mentors recall the solution as doing a fantastic job. Since we intend to return to cantilevered drive this year, we have of course revamped the design; a screenshot is here:
https://plus.google.com/u/0/photos/1...06823682841202
All the advantages of imbedding your bearings in a single piece, without having to make three different bearing block pieces. I thought it was genius when I first saw it, and the material is readily available.
This is genius
One question, so how do you keep overzealous tightening of the two black bolts from crushing your bearing block? (or am I just missing something )
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
