Go to Post The top 3 debates you don't want to bring up in a group of nerds: Mac vs PC vs Linux, Best Programming Language, and Best CAD Program. - EricH [more]
Unread 06-01-2013, 21:42
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: pic: Day 2: Field elements completed
we used the team field drawings to create the pyramid. Instead of using gussets we welded the 1 and 1/2" tube together.
We thought the black 1 and 1/2" pipe was cost prohibitive so we found a ton of galvanized steel pipe and decided to use that. The diameter was a bit off (1.66") but I think it will work for our purposes.
It can easily be pick up by two students, but I think you would need three to move it because of the size of the item.
