Go to Post Remember success in FIRST isn't measured by the trophies. It's measured by the inspiration. - camtunkpa [more]
Unread 07-01-2013, 00:21
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
pic: Need help.
Unread 07-01-2013, 00:22
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Re: pic: Need help.
have you tried a loft between the circular sketch and a sketch on the end of your tube? depending on how you want to do this, you can either make the "midair circle" 2 concentric midair circles with the desired thickness of the shell, or you can loft the part and then shell the feature you created. hint: the first way is easier.
alternate methods: you can draw the profile from the side view and revolve it around an axis through the center of your tube.
you can extrude the circle you currently and choose to extrude it at an angle... solidworks has an option called taper or something and im sure inventor has a similar feature. Basically, there are several ways, but the first will probably be the easiest.
good luck, and if this doesnt work, reply and ill be more specific
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 07-01-2013, 00:24
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: pic: Need help.
Or extrude, then chamfer, then shell
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 07-01-2013, 00:25
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Re: pic: Need help.
Have you tried drawing the entire part, then making a shell of that?
Can I ask what you are trying to make?
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 07-01-2013, 21:31
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Re: pic: Need help.
loft will work, then just shell the whole thing.
keep your cuts close, and your lofts even closer.
disclaimer: I'm a solidworks guy...
Unread 07-01-2013, 22:02
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Re: pic: Need help.
Assuming you want to make a funnel-esque shape, you'll need to do loft twice if you want to use loft to do this. First, you have to loft (using the join option) the outer rim of the face of the cylinder adjacent to the circle to the circle. Then, you have to draw the inner rim of the mouth of the funnel on that circle, then loft it (using the cut option) to the inner rim of the face of the cylinder you previously lofted from (which requires selecting the sketch by navigating to it in the sidebar).
The much easier way would be to create a midplane of the cylinder parallel to the Y-Z plane, use that to sketch the cross-section of the funnel, then revolve it around the cylinder's central axis.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 09-01-2013, 08:27
Spirator Spirator is offline
AKA: Munaum Muhammad
FRC #3132 (The Thunder Down Under)
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Re: pic: Need help.
I agree with making revolves. With a revolve, all you need is to sketch the cross-sectional profile of the part and then revolve it around the axis or centre line.
This video may prove helpful. https://www.youtube.com/watch?featur...&v=lU7cHd0OV7Y
Best of luck!
Unread 09-01-2013, 08:43
President, VEX Robotics, Inc.
Re: pic: Need help.
Yep. Make a revolve with the entire profile, then shell it afterwords. Much faster, much easier to change later.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
