Re: pic: The Cow that Jumped over the moon!
This is legal, but only if the bumpers stay within the bumper zone (2-10 inches).
To the OP, beware the Grapple rule. |
There's a fundamental design flaw with this, if you continue to use the sheet.
http://dsc.discovery.com/tv-shows/my...p-lift-off.htm Quote:
Okay, so here's the rundown of things:
Why do this design? 1. Unable to be interfered from other robots. 2. Directly dump disks into the high and pyramid goals with ease. 3. Able to block disks from opponent robots by bypassing the height limitations. 4. Sit on the pyramid at the end of the game for maximum bonus points. 5. Put other game players in a state of awe and anger and render them incapable of playing the game well. Is it legal? Im fairly sure. That sheet/wall is a rolled up thing of cloth that would fall down after match start, so it would at least begin satisfying the bumper rules there. Maybe the mechanism would be removed. To JesseK: Hmm... okay. We might have folding propellers or cut out that plate in the top to allow airflow then. To GaryVoshol: What is the grapple rule? (I don't know any rule by that name.) |
The following actions are prohibited with regards to interaction with FIELD elements: grabbing, grasping grappling attaching to, damaging, becoming entangled Actions A-D do not apply to ROBOT interactions with the PYRAMID. |
Oh! I didn't realize the sheet was vertical. In that case, there isn't a design flaw so long as the plate is cut to allow air flow. There's a strategy flaw with point # 5 though:
It would be safe as long as they put some sort of shroud over the blades.
The safety issue isn't in the spinning propellors. The safety issue is the vertical sheet (shown as cow print in their CAD picture) preventing the opposing drivers from controlling their robot -- as called out in the blue box beneath R08. I emboldened the appropriate wording above.
That vertical sheet could be made out of a mesh or something instead. It would still serve the purpose of blocking shots, but not interfere with vision. On another note: Do you think that the FRC battery will be able to provide enough power to keep the robot flying at acceptable altitudes? If you've ever flown one of those remote control helicopters, you'll notice that as the battery gets drained the helicopter's maximum altitude dramatically falls, and as the battery gets even lower you can no longer gain altitude. But I think it would be awesome to see a flying FRC robot! |
#10
I am more interested in which motors you will use for the propellers
#11
Do the power calculations required to fly and/or hover the minimum required equipment in a robot given the available motors and battery. It will soon become obvious why there has never been a flying FRC robot before.
#12
This idea is legal. The lower hanging "shield" that is in a crazy cow print would not be needed. If you have flown or been on a helicopter, you need the open bottom or the robot to get air flow. With the open bottom, the prop wash would create a disturbance and affect the flying ability of all frisbee's that fly underneath it, providing great "D".
This being said, it ruins the spirit of the game. Using the battery and CIM motor's, it is possible to lift that much weight with a helicopter style blade |
#13
I used the calculation method from this website assuming that each CIM is just under 1/2hp and weight roughly 3 lbs. You could use all 6 cims or just 1. The math is complicated, but it walks your through pretty well. You certainly would not have a lot of weight room left but it is possible from my calculations.
http://www.heli-chair.com/aerodynamics_101.html Still, not in the spirit of the game |
#15
Also, what happens if you're not hanging onto the tower at the end of the match and your power gets cut? I'm guessing it wouldn't be well-liked to watch a 100 lb robot falling 10 ft to the ground ![]() |
