Go to Post It would appear that your PLTW teacher succeeded in tricking you into learning something after all. Teachers are sneaky that way! - Richard Wallace [more]
Unread 10-01-2013, 09:54
MARS_James's Avatar
MARS_James MARS_James is online now
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Re: pic: The Cow that Jumped over the moon!
Originally Posted by Toa Circuit View Post
What is the grapple rule? (I don't know any rule by that name.)
G14
The following actions are prohibited with regards to interaction with FIELD elements:
grabbing,
grasping
grappling
attaching to,
damaging,
becoming entangled
Actions A-D do not apply to ROBOT interactions with the PYRAMID.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 10-01-2013, 10:16
Oh! I didn't realize the sheet was vertical. In that case, there isn't a design flaw so long as the plate is cut to allow air flow. There's a strategy flaw with point # 5 though:
Originally Posted by R08
4.1.2 Safety & Damage Prevention
R08 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
<blue box>
Examples of items that will violate R08 include (but are not limited to):
A. Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any drivers and/or coaches and/or interfere with their ability to safely control their ROBOT
GitHub
Unread 10-01-2013, 10:21
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
It would be safe as long as they put some sort of shroud over the blades.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2013, 10:25
The safety issue isn't in the spinning propellors. The safety issue is the vertical sheet (shown as cow print in their CAD picture) preventing the opposing drivers from controlling their robot -- as called out in the blue box beneath R08. I emboldened the appropriate wording above.
GitHub
Unread 10-01-2013, 10:30
AKA: Matt B
FRC #1771 (1771)
Ah. Yes, I wasn't quite sure what that was.
That vertical sheet could be made out of a mesh or something instead. It would still serve the purpose of blocking shots, but not interfere with vision.
On another note: Do you think that the FRC battery will be able to provide enough power to keep the robot flying at acceptable altitudes? If you've ever flown one of those remote control helicopters, you'll notice that as the battery gets drained the helicopter's maximum altitude dramatically falls, and as the battery gets even lower you can no longer gain altitude.
But I think it would be awesome to see a flying FRC robot!
1771- Mentor (2015)
Unread 10-01-2013, 10:33
MARS_James's Avatar
Always Scouting
AKA: James Comstock
I am more interested in which motors you will use for the propellers
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Do the power calculations required to fly and/or hover the minimum required equipment in a robot given the available motors and battery. It will soon become obvious why there has never been a flying FRC robot before.
Unread 10-01-2013, 10:36
dondanvm dondanvm is offline
FRC #4213
dondanvm is an unknown quantity at this point
This idea is legal. The lower hanging "shield" that is in a crazy cow print would not be needed. If you have flown or been on a helicopter, you need the open bottom or the robot to get air flow. With the open bottom, the prop wash would create a disturbance and affect the flying ability of all frisbee's that fly underneath it, providing great "D".
This being said, it ruins the spirit of the game.
Using the battery and CIM motor's, it is possible to lift that much weight with a helicopter style blade
Unread 10-01-2013, 10:40
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Care to throw some numbers at this?
Unread 10-01-2013, 11:10
FRC #4213
I used the calculation method from this website assuming that each CIM is just under 1/2hp and weight roughly 3 lbs. You could use all 6 cims or just 1. The math is complicated, but it walks your through pretty well. You certainly would not have a lot of weight room left but it is possible from my calculations.
http://www.heli-chair.com/aerodynamics_101.html
Still, not in the spirit of the game
Unread 10-01-2013, 11:17
MARS_James's Avatar
Always Scouting
AKA: James Comstock
Did you factor in the weight of bumpers, metal, crio, motor controllers, etc.?
Cause I can't imagine this happening but I would love to be suprised
Unread 10-01-2013, 11:27
FRC #4213
Yes. Light light light everything. How bout some carbon fiber!!! The battery is the biggest weight. The rest of the electronics are fairly light compared. Build the frame small and start with the props vertical so you do not need much in the way of metal/carbon fiber or bumpers. This is all conceptual, not anything you can or should try. It would get shut down for ruining the spirit of the game as well as safety (carbon fiber explodes).
Unread 10-01-2013, 11:30
AKA: Matt B
FRC #1771 (1771)
Exactly. The bumpers, chassis, cRIO, wireless router, PD block, and all the wires will be weight prohibitive. Even if you got the robot flying, you wouldn't have enough weight left to make any sort of manipulator.
1771- Mentor (2015)
Unread 10-01-2013, 11:52
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Using the method from that website:
Area = #rotors * diameter^2 * pi/4
Area = 4 * 14in^2 * pi/4 = 616 in^2 = 4.28 ft^2
Power will be limited by the battery and main breaker, with a maximum continuous power of:
Power = voltage* current = 12 V * 120 A = 1440 W = 1.93 HP
PL = Power/Area = .452 HP/ft^2
TL = 8.6859 * PL^(-.3107) = 11.12 lb/HP
Thrust = Power * TL = 11.12 lb/HP * 1.93 HP = 21.5 lb
The battery alone is 12 lb. Each CIM is 2.8 lb. If I did the math correctly, I don't think you can fly.
Unread 10-01-2013, 12:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Originally Posted by Jim Wilks View Post
6 CIM's all working near full power? You'd trip the main 120A breaker in a few seconds.
Bingo.
Each CIM wouldn't be experiencing very heavy loads though. The stall current is 133 Amps, and the free current is 2.7 Amps.
While they wouldn't be at free current, they wouldn't be drawing massive amounts of current if they are powering a light-weight rotor, would they?
If the CIM is operating at full power (337W) with, let's assume 0.65 efficiency (max efficiency, anti-conservative, but I'm only making a point) draws about 43A, which can pop each CIM's breaker, and with just 3 (let alone 6) you're running the risk of blowing the main breaker too.
This too.
