Go to Post Part of FRC and design/engineering is perseverance. Keep your chin up, your thoughts positive, and have respect for your work and the work of your teammates. - Nathan_Fraser [more]
Unread 10-01-2013, 11:30
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: pic: The Cow that Jumped over the moon!
Originally Posted by MARS_James View Post
Did you factor in the weight of bumpers, metal, crio, motor controllers, etc.?
Cause I can't imagine this happening but I would love to be suprised
Exactly. The bumpers, chassis, cRIO, wireless router, PD block, and all the wires will be weight prohibitive. Even if you got the robot flying, you wouldn't have enough weight left to make any sort of manipulator.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2013, 11:52
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Using the method from that website:
Area = #rotors * diameter^2 * pi/4
Area = 4 * 14in^2 * pi/4 = 616 in^2 = 4.28 ft^2
Power will be limited by the battery and main breaker, with a maximum continuous power of:
Power = voltage* current = 12 V * 120 A = 1440 W = 1.93 HP
PL = Power/Area = .452 HP/ft^2
TL = 8.6859 * PL^(-.3107) = 11.12 lb/HP
Thrust = Power * TL = 11.12 lb/HP * 1.93 HP = 21.5 lb
The battery alone is 12 lb. Each CIM is 2.8 lb. If I did the math correctly, I don't think you can fly.
Unread 10-01-2013, 12:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by Jim Wilks View Post
6 CIM's all working near full power? You'd trip the main 120A breaker in a few seconds.
Bingo.
Originally Posted by nighterfighter View Post
Each CIM wouldn't be experiencing very heavy loads though. The stall current is 133 Amps, and the free current is 2.7 Amps.
While they wouldn't be at free current, they wouldn't be drawing massive amounts of current if they are powering a light-weight rotor, would they?
If the CIM is operating at full power (337W) with, let's assume 0.65 efficiency (max efficiency, anti-conservative, but I'm only making a point) draws about 43A, which can pop each CIM's breaker, and with just 3 (let alone 6) you're running the risk of blowing the main breaker too.
This too.
artdutra04's Avatar
VEX Robotics Engineer
There's a fundamental design flaw with this, if you continue to use the sheet.
http://dsc.discovery.com/tv-shows/my...p-lift-off.htm
They demonstrated this with miniature helicopters -- the helos could lift themselves in unison when all connected to the same wooden lattice. Yet once they mounted a sheet underneath the lattice, the helos couldn't get off the ground.
Technically, if the surface underneath the bees/mini-helicopters was curvedl, they could use the Coanda Effect for lift.
Nope. The mechanical power output is found by multiplying the torque times the rotational speed. For a DC brushed motor, torque and speed are inversely related, thus the output power forms a parabola with a maximum value at the mid-point. A CIM Motor at peak output power will be drawing 67.9 amps.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-01-2013, 09:38
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
I am fairly sure this is illegal because you blocking the sight of a drivers station and it is not safe at all. plus with disks flying and hitting the wall you better hope that is a stable system or everyone would get to see a cliche ladder tipping scene.
