Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 18-05-2007, 07:19
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: pic: Vex Mecanum Wheel
as he said, they do work well, our only problem was getting the 4 motors to run the same speed. you might have seen us playing with it in the pit in Atlanta if you were in Curie, while our robot was out at a match.
EDIT: Also, you don't want to know how many brackets were broken trying to clean them from the rapid prototyper's "build-up" stuff. They used to be pretty flimsy. >_>
Unread 19-05-2007, 21:40
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Are you using this for prototyping purposes for FRC, just to be cool, or intended to be used for FVC?
If being used for FVC, how much labor is involved in creating the wheels, and would the results really be worth it over the new "large omni wheels" (also 4" diameter)? Granted, if the game has large inclines (or obstacles) like "Half Pipe Hustle", a mecanum system would allow much greater ability to climb (although still requiring a fair bit of precision). Otherwise I don't see a whole lot of advantage for much greater effort put into producing the wheels.
Also, what materials are the rollers made out of?
In my experiences with my vex mecanum wheels the labor is worth over using the 4 inch omniwheels. And with my Mecanums climbing stuff (anything less that 2") was super easy and require minimal percision. The Ideal angle of approach was less that 30 degrees but they would climb at up to 45 degree angle of approach.
-Dustin Benedict
Unread 21-05-2007, 09:09
I agree. The first wheel I made took ~8 hours since I was trying to get it right. I created the other 3 about 3 hours, 2 of which were drilling/filing. After you figure the first one out it's pretty easy to figure out how to mass-produce them.
Very worth the effort to figure a problem out when it has substantial gain. It even took less time than a 3-D printer takes to "print" a design you give it
GitHub
Unread 18-01-2013, 10:31
hokagedetam hokagedetam is offline
hokagedetam has a spectacular aura abouthokagedetam has a spectacular aura about
Can you send me a drawing mecanum wheel?
Thank you very much
Unread 18-01-2013, 10:47
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Thank you very much
This is a very old thread --are you looking for FRC-level VEXpro mecanum wheels? 2D and 3D models are here: http://www.andymark.com/mobile/default.aspx#C53
Welcome to CD! Great job trying the search, but try to check the thread age.
pic: VEX Mecanum Concept Wheel JesseK Extra Discussion 18 17-05-2007 10:27
pic: Mecanum Wheel Project - Rev. D Madison Technical Discussion 17 07-08-2006 18:19
pic: Mecanum Wheel Project - Rev. E Madison Technical Discussion 8 13-07-2006 13:31
pic: 2" Mecanum Wheel Tytus Gerrish Technical Discussion 17 22-04-2006 12:22
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
