Go to Post :D NASCAR is way harder than we thought. - SL8 [more]
Unread 18-01-2013, 20:20
falconmaster's Avatar
AKA: Ledge
FRC #0842 (Falcon Robotics)
pic: starting config
Unread 18-01-2013, 20:26
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: pic: starting config
This year's robots are going to be seem absolutely microscopic.
Unread 18-01-2013, 20:27
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
I really like this design. 842 has done an awesome job in documenting their design process to the community this year. The whole intake combined with the scissor feeder and cylinder pulling the frisbee into the shooter is awesome.
Some questions I have:
-Does this prototype arm fit within the 54" vertical cylinder? Just interested...
-Do you guys plan to start the arm upright and then run the rest of the match with it down? Otherwise it seems really tippy with that frame.
-How do you plan to articulate the arm?
-What are you planning for hanging? A simple 10 point hanging claw on the arm or something more complex?
Thanks for the reply.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 18-01-2013, 22:24
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is online now
John Rangel
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
Hi. Thanks for the compliments. The prototype is a little bit larger than the actual arm. Actual arm will be about 40" long and does fit in the cylinder but we can only have the arm pivot backwards a certain amount. The arm will start upright and will most likely drive it upright unless of course we see a robot coming near ours in which we would lift the arm up to protect it. We are going to mount as much weight as possible to the ground to help with that. The arm will most likely be articulated with 2 mini cims hooked up to a custom transmission and will be mounted in a way similar to team 27 from the year 2011. For our hanging, we are going to mount chains to the sides of the arms and attach hooks on both sides. This will let us climb up the pyramid in a reasonably fast amount of time while also shifting our center of gravity to help climb up it. You can find the climbing routine on our team activity sheet:
https://docs.google.com/document/d/1...Uz8GtISI0/edit
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 18-01-2013, 22:29
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Interesting Idea. I like the "super module" design.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
