Go to Post Something is subtly different about the competition environment that makes everything worse. - kaszeta [more]
Unread 01-25-2013, 12:45 PM
Jhultink Jhultink is offline
AKA: Jaredt Hultink
FRC #2771 (Code Red Robotics)
Jhultink is a jewel in the roughJhultink is a jewel in the roughJhultink is a jewel in the roughJhultink is a jewel in the rough
Re: pic: Team 610 - 2013 Electronics Board
Originally Posted by androb4 View Post
The smiley is covering SOOMMETHIIINNG..
I think it is just a battery tester
Unread 01-25-2013, 01:35 PM
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
For a more relevant question... How is the new 2CAN working for you, and CANbus in general, so far in 2013?
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 01-25-2013, 02:51 PM
Data Nerd
FRC #0079
I'm not 610 but I can tell you that 79 hasn't had any problems with either the 2CAN or the CANbus in general this year. The only major problem we have is that our electrical team has a nasty habit of pull Jags off the bus that we still talk to and it introduces a stutter into the system. Despite our best efforts we have not been able to rectify this problem (the electrical team removing Jags, the stutter is fixed by not writing to that Jag).
Unread 01-26-2013, 08:17 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Well, another Saturday in the books. Figured I'd post a quick response before a night-time Timmie's run...
I can't really comment about the drivetrain, other than the fact that I really like it, and that student designer Ryan Tam (Gr. 11) deserves a tons of recognition for the design and manufacture of it. He worked under the mentorship of Mr. Stehlik, and there are a lot of neat little details in it that just don't show up in this picture... (i.e. all 4 side plates are identical, how the square channels are securely connected to the side plates with only one fastener, the in-between CIM "floating" encoders + mounts)
It's not flashy, but it's really well thought out, with a ton of detail to maximize ease of machining, assembly, and maintenance.
To answer some questions:
Yes, the smiley is covering something. We noticed one of the frisbee manipulating components got into the picture, and needed to be covered up.
The air tank holder is custom cut 1/4" lexan on our CNC router, again designed by Ryan Tam. It is basically four holes, as the tanks have a nice raised boss at each end that you can support them by.
As for CAN, it worked well for us last year, but we had a few hundred lines of code dedicated to CAN Error Recovery. Without it, we would have been dead in the water. We used the black serial adapter last year, and this is the first year we are using the 2CAN. It's still a bit early to give any meaningful feedback, as all we've done is some light open-loop driving.
Unread 01-26-2013, 09:14 PM
Data Nerd
FRC #0079
Im interested in the CAN Error Recovery stuff. Could you elaborate?
Unread 01-26-2013, 09:39 PM
AKA: Mr. Lim
We coded our robot in Java using the Command-based template.
Within each subsystem that used a Jaguar, we ensured that whenever we caught a CANTimeOutException, we called a subsystem-specific recovery method to re-initialize and verify the configurations of all Jags within that subsystem.
This ended up being a bit tricky for some sub-systems, as we switched Jaguar configurations depending on the task we were doing. i.e. the drivetrain could be in VBus, Position, or Speed mode at different times in the match. We had to keep track of these states, and restore them gracefully.
We had to handle the deadlock condition as well, because sometimes the error recovery would cause more CANTimeoutExceptions if the affected Jag wasn't ready to be re-initialized. Gracefully handling this condition without stopping your entire CAN communications bus was a bit tricky.
At worst we only wanted a single sub-system to "pause" just long enough to gracefully re-initialize the Jaguars after an exception. All the other sub-systems had to keep going as if nothing happened.
Unread 01-26-2013, 10:06 PM
Data Nerd
FRC #0079
Interesting, maybe I'll have to chat with you guys in more depth post season about this. We use Iterative and C++ so your approach wouldn't work for us.
Unread 01-26-2013, 09:40 PM
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Is the perimeter of this thing really under 112 inches? It looks huge!
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 01-26-2013, 09:56 PM
AKA: Mr. Lim
Our perimeter measures out at 110".
The VersaWheels do funny things to the perspective.
Unread 01-26-2013, 11:09 PM
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
This is especially true with 256's drivetrain.
http://www.chiefdelphi.com/forums/sh...hreadid=112141
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 01-26-2013, 11:13 PM
WileyB-J's Avatar
WileyB-J WileyB-J is offline
4976 Georgetown Rebels
FRC #4976 (Rebels)
WileyB-J will become famous soon enoughWileyB-J will become famous soon enough
Sweet multimeter.
Unread 05-29-2013, 06:07 PM
Tmaxxrox97's Avatar
Tmaxxrox97 Tmaxxrox97 is offline
FRC #2512 (Duluth East Daredevils)
Tmaxxrox97 is an unknown quantity at this point
Is there a CAD file of this drivetrain available? The floating encoders and mounts sound like a really cool idea and I would like to take a look at them if I could.
If it (the robot) is strong enough to do the task, it should be able to handle any abuse a 16 year old with a joystick can throw at it. --MrBasse
Unread 05-30-2013, 01:20 PM
jamierose jamierose is offline
FRC #4039 (MakeShift)
jamierose is just really nicejamierose is just really nicejamierose is just really nicejamierose is just really nicejamierose is just really nice
We will probably upload our CAD to www.frc-designs.com at some point in the future. I would do it now, but unfortunately, I, and many other members of our team, are currently writing exams, so we don't have much time to sort out our CAD and upload it. I'll explain a bit about how our encoders are mounted.
As you can see in the picture, our CIMs are pretty close together. We made a small plastic piece with our 3-axis CNC router that looks like a rectangle with a semi-circle cut out on either side of it. These portions of a circle are made to fit perfectly around a CIM. There was a hole in the middle of the piece for an encoder to fit through so we could screw it on. We then slid the piece in between the CIMs. The friction was enough to keep the plastic piece in place.
We then used our usual method to connect the encoder to the shaft. On 610 we use a technique we borrowed from 188, which is using surgical tubing to connect an encoder to a shaft. We simply slide the encoder into one end of the surgical tubing and the shaft into the other end. It works extremely well and we have never had issues with it.
If you have any more questions feel free to ask or message me! Hopefully we'll be able to get that CAD uploaded soon.
