Re: pic: frc 2200 chassis
My guess is that is just 1/2 of the bot
Quarter inch aluminum with 2 CIM drive? I'm scared for you.
![]() Last edited by Bochek : 27-01-2013 at 21:04. |
6 CIMs the other 2 for the pod are not attached yet
That gearbox only looks like it can hold 1 CIM.
Look closely at the small plate: the other 2 go inside the frame.
(Funnily enough, passed my Simbotics post without even knowing it.) Last edited by CalTran : 27-01-2013 at 20:47. |
There was not enough room to fit 3cim's and a shifting piston all on the inside. It was a simple matter of how to make it all fit. With the reduced dimensions of the robot this year, a standard 3/4" bore 1/2" stroke bimba piston was too long to fit we redesigned to use a shorter "flat line" piston.
Or they have no drivetrain and only climb..
