Go to Post ... six weeks, it's too long, but not long enough. - Stillen [more]
Unread 27-01-2013, 19:22
Andrew Lawrence
Re: pic: frc 2200 chassis
Originally Posted by Blmred View Post
6 CIMs the other 2 for the pod are not attached yet
That gearbox only looks like it can hold 1 CIM.
Unread 27-01-2013, 19:26
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Look closely at the small plate: the other 2 go inside the frame.
Unread 27-01-2013, 19:53
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
That's an...interesting concept. Will an enlightenment as to why be following soon? Just a space saver?
(Funnily enough, passed my Simbotics post without even knowing it.)
Academic Student (Forever)
Unread 27-01-2013, 20:39
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
There was not enough room to fit 3cim's and a shifting piston all on the inside. It was a simple matter of how to make it all fit. With the reduced dimensions of the robot this year, a standard 3/4" bore 1/2" stroke bimba piston was too long to fit we redesigned to use a shorter "flat line" piston.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
