Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 27-01-2013, 19:53
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: pic: frc 2200 chassis
Originally Posted by Tristan Lall View Post
Look closely at the small plate: the other 2 go inside the frame.
That's an...interesting concept. Will an enlightenment as to why be following soon? Just a space saver?
(Funnily enough, passed my Simbotics post without even knowing it.)
Academic Student (Forever)
Unread 27-01-2013, 20:39
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
There was not enough room to fit 3cim's and a shifting piston all on the inside. It was a simple matter of how to make it all fit. With the reduced dimensions of the robot this year, a standard 3/4" bore 1/2" stroke bimba piston was too long to fit we redesigned to use a shorter "flat line" piston.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
