Go to Post I, as a programmer, always strive to have the entire robot operate with as little driver input as possible. Those pesky humans.... - dellagd [more]
Unread 28-01-2013, 23:41
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
pic: Is this legal?
Unread 28-01-2013, 23:42
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: pic: Is this legal?
Are you cutting away that corner? It is entirely legal however your bumpers will have to follow that cut out because its now part of your frame perimeter.
Unread 28-01-2013, 23:46
EricH EricH is online now
Exactly what I was going to say, with one minor addition: Make doubly sure you have 8" bumpers on each side in addition to the 1" bumper segment on the cutout.
I'd ask what the purpose is, but I'm guessing it's either pyramid climbing in some way, or you're having a little bit of trouble with the frame perimeter and want to give yourself 1.14 inches instead of 2 just to have a little bit of cushion.
Unread 28-01-2013, 23:48
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
So bumpers have to fellow the frame perimeter?
Unread 28-01-2013, 23:55
MrForbes MrForbes is offline
Code:
R22
ROBOTS are required to use BUMPERS to protect all outside corners of the
 FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must
 be placed on each side of each outside corner (see Figure 4-2).
I don't see how you're going to put an 8" bumper on the 1.4" wide side of the frame corners.
I think you might be able to get away with a 1/4" chamfer on each of the four corners....
Unread 29-01-2013, 00:02
Originally Posted by MrForbes View Post
Code:
R22
well those are 1" chamfers. The rule says "Protect all outside corners" and they will have traded one corner for two. The rule then says "at least 8inches of BUMPER must be placed on each side of the corner....so maybe any sort of corner cut under 8 inches is not allowed. At least thats what the rule would suggest. So I would have to retract my previous answer and call this illegal in that case.
There shouldn't be a reason you would get away with getting to call your frame perimeter smaller while not following the rest of the rules that subsequently follow
Unread 29-01-2013, 00:08
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
The issue of a side shorter than 8" was cleared up in the Q&A and with a rule update. It was ruled that there must be at least 8" of bumper on either side of a corner. If a side was shorter than 8", the remaining 8" of bumper must wrap around the next corner.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 29-01-2013, 00:17
Im just going to keep not reading the Q&A and ask you at competition if I have questions.
Unread 29-01-2013, 00:21
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Link to the question and response please?
Academic Student (Forever)
Unread 29-01-2013, 00:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Wrapping is described in the bottom figure of update 2013-01-15, and mentioned in Q137.
Note that this business about the corner protection wrapping around other corners is new for this year.
Unread 29-01-2013, 09:15
That does not make sense.
Oh well.....
Unread 29-01-2013, 12:40
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Oh well.....
I think the rules committee made a creative interpretation to allow a frame side to be less than 8". The rules committee does not have to make sense. To quote Lily Tomlin "They are omnipotent" Now tell me where that quote came from.
In terms is the pic legal? Only your inspector will know for sure. But you bumper will have to comply with R29 & wrap around the 1" fillet so that is is fully supported.
R29
BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-6). To be considered supported:
A. a minimum of 1 in. at each end of the BUMPER must be backed by the FRAME PERIMETER,
B. the gap between the backing material and the frame must not be greater than ¼ in., and
B. no section of BUMPER greater than 8 in. may be unsupported.
Unread 29-01-2013, 17:24
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
If you have a Q for Q&A, make sure you reach the party to whom you are speaking <snort>.
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 30-01-2013, 21:24
GaryVoshol's Avatar
Cogito ergo arbitro
I've been thinking about this. That 1.414" section of Frame Perimeter would have to have its own section of bumper - complete with plywood, noodles, fasteners. Pay attention to R29A.
(since 2004)
