Go to Post The spirit of the game, and the game are essentially two different things. - ttldomination [more]
Unread 30-01-2013, 00:18
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
pic: 3992 Sheet Metal Chassis
Unread 30-01-2013, 00:23
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Re: pic: 3992 Sheet Metal Chassis
Looks really nice! I like the team branding on the sides for weight reduction. Do you think that all the material removal on the chassis channels near the middle might reduce the stiffness of your chassis? Overall I am excited to see this come to life. What are you doing for ground clearance? Did you design this to go over frisbees or push them out of the way?
Also what are your plans for chain tensioning?
Team 1716 is doing a sheet metal drivetrain this year as well and I will try to post pics soon and maybe CAD as well.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 30-01-2013, 00:25
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Is this only 4 wheeled? What thickness metal are you using?
Unread 30-01-2013, 03:41
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
It's attention to detail like this that makes me wish we had transparent bumpers
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 30-01-2013, 06:24
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
I'd guess mecanum.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 30-01-2013, 19:40
ksafin's Avatar
AKA: Kirill Safin
To answer some questions:
This is a 4 wheeled mecanum drive train. We will be using belts, not chains. For belt tensioning, we will simply slide the gearbox (it's slotted) as it will sit on the holes on the inner length plates.
The metal is 1/8" thick.
As far as whether our cuts on the length plates would reduce stiffness, we weren't too sure, so we have two standoffs there that we hope will do it. Ultimately I feel that any loss of rigidity won't be too significant but it's something we'll see once we get this cut and assembled.
Our design is to have minimal ground clearance; it would push frisbees out of the way. The bigger reason was to have our mecanums just touch the ground though; lower Center of Gravity by doing so.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 30-01-2013, 19:46
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Good approach. Right now it's impossible to predict how much of an issue this might be, but I can see teams (ourselves included) adding "aero kits" to their bots to reduce ground clearance and keep firsbees out of the way.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 30-01-2013, 19:56
In mecanum drives, a semi-loose chassis that can conform to bumps in the field is actually what you want.
With that said, some of those cutouts are quite extreme. Although the shapes look cool, they can be done a lot better with a lot more added strength. A simple truss pattern would be much better.
