Thread Tools |
Rating:
Display Modes |
Re: pic: Team 1687 Doherty Technical Forces - Chassis
It doesn't do much to affect maneuverability, not at that level, at least that I know about. Visualizing the bumpers... It sounds like an interesting idea; I assume that bumper supports just aren't shown in this render. (Magic doesn't count as a support, sorry. Neither does simply constraining in CAD...) |
The bumper hardware can be extensive but there still has to be a frame perimeter for which the bumpers are supported against. When you wrap the string around your robot with out the bumpers where does the frame perimeter support your bumpers? |
I agree with Allen. The bumpers (or any attached bumper hardware) do not define the frame perimeter -- only what's on the robot defines the frame perimeter.
Additionally, that is definitely a bit of stretch for the definition of "bumper mounting hardware" that I wouldn't stake my season on without a clearer definition from Q&A. Fortunately, it looks like it's easy to accommodate hard mounts on the frame itself for bumpers & a frame perimeter everywhere except the front corners. Quite honestly, nothing defines what materials hard frame mount must be made out of, so it can technically be 1/32" sheet metal for the front corners. The perimeter shape in a nice way of ensuring the 112" distance is met. Kudos to whomever thought of that idea on your team! Last edited by JesseK : 31-01-2013 at 09:50. |
Looks like a unique design. Can't wait to see it in action at WPI.
On a slightly different note, do I spot two pneumatic actuators on each gearbox?
And a pretty interesting layout of 4 larger actuators in the top view, I am very curious to see how this turns out. Good luck! |
that's actually what inspired it. |
#10
yeah sorry about that, just thought team 179 didn't really think about the year.
#12
179 did this in 2005, 2007 (only the front pair) and 2008 (only the front pair).
234 also did it in 2007. All four robots were highly successful, I don't think the inset wheels will cause an issue for you. |
#13
To answer some questions:
-We have complete confidence in the turning and stability of this drivetrain. In addition to past success by team 179 and others with this style of drive, we've done the math -- it will turn with comparable scrub to a 38*28 6WD. The system is just structured somewhat differently than 179's, taking liberal inspiration from the West Coast Drive, the sheet metal work of teams 148, 228, 488 and others, and 2791's "belt in tube" system. -Why bother? Some reasons we considered:
-Here's a sketch showing our robot's bumper perimeter. The two front segments are each the minimum length. Framing which supports the bumpers on this odd-shaped perimeter not shown, much of the real load-bearing hardware does come off with the bumpers, but there is enough support on the robot to legally support the bumpers, and create a well-defined frame perimeter for inspection. ![]() Last edited by Joe G. : 30-01-2013 at 23:43. |
