Go to Post Forget Pool Basketball or Pool Volleyball, it's time for some Pool Rack n' Roll! - Conor Ryan [more]
Unread 31-01-2013, 12:14
JoesephWhite's Avatar
JoesephWhite JoesephWhite is offline
Alumni, Mentor for 2341 & 4612
FRC #4612 (RoboRockets)
JoesephWhite is an unknown quantity at this point
Re: pic: 3247 Robopack Frame Design
Easiest way to fix both these issues would be to drop a Toughbox Mini in (with an appropriate ratio) and to add the AndyMark standoffs between the gearboxes, in addition to any "additional support" you might have planned (e.g. replacing the front and back pieces with C-channel or tubing). A rigid belly pan would also help a little.
We have the AndyMark standoffs on there I just haven't had the chance to put them in CAD
Could you explain to me why we should you the Toughbox vs. the CIMple?
