31-01-2013, 12:49
Re: pic: 3247 Robopack Frame Design
Originally Posted by Taylor
The problem with direct-driving Minis is that the gearbox is taller than the 6" wheel.
I think the flat plate mount might be, but I am pretty sure the actual "box" isn't. The output shaft is under 2 inches away from the bottom of the bent plate gearbox. Mounting this might be tricky.
