Go to Post The only constant in FRC is change. Learning to adapt to change in competition is the best way to prepare for change in real life. - Jessica Boucher [more]
Unread 02-02-2013, 02:39
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: pic: Got wire?
Originally Posted by Becca334 View Post
Underneath the cRIO we have a sheet of lexan inbetween the frame and the cRIO.
Hopefully the screws (if any) are not capable of conducting current from the robot's aluminum base plate to the cRIO's threaded holes. (Even if they are, it's easily fixable.)
Originally Posted by wilsonmw04 View Post
I like it for the most part, but I have a problem: the main power switch. Please, make sure that it is easily accessible or you are going to have a rough first event when you have to find a suitable place for it.
I don't think that main power switch (120 A breaker) is particularly inaccessible from the exterior of the robot. Although a full determination will depend on what goes on top, as it stands now, if I were inspecting it, I'd pass that aspect of it without question.
