Go to Post If I can make a comeback, so can you. - Warren Boudreau [more]
Unread 03-02-2013, 00:39
voxelcreative voxelcreative is offline
Digitization and Augmentation Pro
AKA: John Schurman
FRC #1818
voxelcreative is an unknown quantity at this point
Smile Re: pic: 3D printing for bracketry
I'm baaaacccckkkk!!! :-)
Here's the files on Autodesk 360 in the .STL file format. Please note that I am using my personal Cube (Ver. 1) when printing these, which is super wacky and doesn't print things at the scale it "thinks" it is. So, I'm trying to post the .STL files before the odd scaling I have to do to make them work for a Cube, and the scale should be correct to real world. You can always check by importing these files into Inventor/Solidworks/Meshlab/etc. and virtually inspecting them. I hope to see printed parts on other teams robots soon!
Sidecar Brackets!!
Sidecar bracket 1 - http://a360.co/Xg8fmA
Sidecar bracket 2 - http://a360.co/Xg8pui
Sidecar bottom plate (not tested) - http://a360.co/X5cinQ
BONUS!!!! Here's a bracket to mount the window motor and a hub that will let you slide different "adapter feet" on for various uses.
Window Motor Mounting Bracket - http://a360.co/Xg8oGL
Window Motor Dovetail Hub - http://a360.co/Xg8spU
And as always, PLEASE let me know if you print any of these and they do not work. I never turn down a challenge.
