Go to Post We know that the real goal of FIRST is not for this robot to win, but that we learn something. If i was on robotics to win, it wouldn't be nearly as fun. - Nin_estarSaerah [more]
Unread 06-02-2013, 12:38
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Re: pic: Team 3266's Robot
Originally Posted by Robby Unruh View Post
We actually chose pieces of plastic duct taped to the walls of our hopper over the bucket. Works just as well!
Just to clarify, we used polycarb and duct tape as a quick fix to solve a jamming problem with the hopper, but we replaced it with .120" aluminum yesterday. This is just our practice robot.
Originally Posted by thef.22raptor View Post
NIIICCEE how does it work
Our drivetrain is pretty simple, 4WD with VexPro Versa wheels and AM Supershifters. Personally I highly recommend the Versa wheels, we're very happy so far with the traction and the wieght.
Our shooter uses a 6" KOP wheel as the flywheel, direct drive off a CIM motor, we have an encoder on the top of the shaft to measure RPM.
For the hopper there is a chute on the back that the frisbees are fed into, it works exactly the same as a 5 gallon bucket. Once the frisbees are stacked in the hopper there is an arm powered by an air cylinder that "kicks" the bottom frisbee into the flywheel.
To raise and lower the shooter we're going with an air cylinder to switch between the loading angle and shooting angle. Just keeping it simple for this system.
And the climber design is still being worked on
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
