Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
Unread 06-02-2013, 22:45
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
pic: 3992 Drive Train
Unread 06-02-2013, 22:50
rcmolloy's Avatar
rcmolloy rcmolloy is offline
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Re: pic: 3992 Drive Train
Out of curiosity, what is the thickness on the side plates. My guess is that it looks like 1/8.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
ksafin's Avatar
AKA: Kirill Safin
Correct.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 06-02-2013, 22:51
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Looks very pretty. Seems like you chose to compromise a tremendous amount of strength for appearances though. I hope you are planning on using the bumpers as a structural member
Mentor 2415
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Just out of curiosity, how come you guys went with belt drive mecanum rather than the normal direct drive?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 06-02-2013, 22:56
ksafin's Avatar
AKA: Kirill Safin
From some collision tests and general observation, we don't see too much of a lack of strength. It's more than strong enough all-around - the only primarily weak point is at the "X" cut out on the long side-plates, but even that is fairly strong and will be stabilized further with standoffs yet to come.
When you say direct drive, do you mean direct attachment to a gearbox?
There were a few logistical reasons we didn't do that, but overall because we had the resources to make a belt drive right away.
Unread 06-02-2013, 22:58
dodar's Avatar
Ya thats what I meant. So it wasnt for like CG or spacing for other things? It was just because you could?
Unread 06-02-2013, 23:00
ksafin's Avatar
AKA: Kirill Safin
CG was one of the points that came up, actually (I forgot about it as I replied to your initial inquiry).
For our climbing mechanism we need as much weight center as possible, so gearboxes at both ends were a barrier.
But otherwise it was less of "we could" than "we could do it given what we have now, or wait to order more parts to perform the same function" so we went with what we had.
Unread 06-02-2013, 23:05
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I'm going to quote my post in the other thread you posted with your practice robot.
Originally Posted by Gregor View Post
From what I can tell, you are using CIMple boxes, the kit sprockets (39 and 42 tooth), and 8" mecanums.
This gears you for a very nifty 30 fps. Consider halving that, on even a third of that. That is far too fast for an FRC bot, and will be near uncontrollable for your drivers.
A quick fix would be to switch to Toughbox minis with a 12.75:1 or a 10.71:1 ratio.
Have you actually driven this yet? It is far too fast.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 06-02-2013, 23:06
rcmolloy's Avatar
Good to hear this statement. I could see definitely see some buckling of the material inwards with a solid hit from another robot at the right angle. You guys can keep the aesthetic appearance of the drive super nice with pocketing that benefits not only the appearance but functionality as well.
Unread 06-02-2013, 23:12
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
How are you planning on mounting your bumpers?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 06-02-2013, 23:14
ksafin's Avatar
AKA: Kirill Safin
Using special shaped C-Channelish brackets that are ~ 4.8" high and about ~0.75" in. IE, it basically wraps around the side and front plates. Then the top and bottom of the C-Channel have a hole that mounts to the plate itself, and the long part to the bumper plywood.
Unread 06-02-2013, 23:24
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
I second this, are you planning on having a 30fps drive?
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 06-02-2013, 23:29
ksafin's Avatar
AKA: Kirill Safin
We had the previous drivetrain (the 80/20 one) driven, and it seemed to be fine.
I'm not particularly sure what the software team did, its possible that they set a cap on the motor output speed (such as setting 75% as a max for the motor controllers).
Unread 06-02-2013, 23:31
ksafin's Avatar
AKA: Kirill Safin
But I can say for sure that it was nowhere near 30 fps.
