Go to Post stop whining about something that can be solved by working harder. - artdutra04 [more]
Unread 07-02-2013, 00:21
maxweberh's Avatar
maxweberh maxweberh is offline
AKA: Max Weber
FRC #3929 (Atomic Dragons)
maxweberh has much to be proud ofmaxweberh has much to be proud ofmaxweberh has much to be proud ofmaxweberh has much to be proud ofmaxweberh has much to be proud ofmaxweberh has much to be proud ofmaxweberh has much to be proud ofmaxweberh has much to be proud of
pic: Team 3929 Teaser
Unread 07-02-2013, 00:23
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
Re: pic: Team 3929 Teaser
So which wheel do you suppose gives the best performance? We bought a set of the blue ones and are fairly satisfied with the performance of them. at about 3/8th compression and a 3:1 / 1:1 BAG motor set up we're getting somewhere around 275 inches and about 20 inches of spread. This is from a horizontal shooting position, table height.
Academic Student (Forever)
Unread 07-02-2013, 00:26
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I think they are using all 3.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 07-02-2013, 03:12
Brandon_L Brandon_L is offline
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Lookin' good!
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 07-02-2013, 07:55
maxweberh's Avatar
AKA: Max Weber
We have chosen this set up that you see based on many hours of testing with our shooter. Basically they are set up in order of decreasing tread density. This is basically because we saw the green ones, although offering usually better results, they got chewed up pretty good. This set up pretty much voids any need to decrease the first few wheels. Of course we will continue to test this with our final shooter because we are planning on having to change out wheels rather frequently because even in this set up the less dense green wheels still get a little battered. If you want to see more of our shooter prototypes check us out at http://youtube.com/user/FRC3929
-max
Team 3929 Atomic Dragons (2012-XXXX)
2014 Lenape District Winners
Unread 07-02-2013, 12:43
CalTran's Avatar
Missouri S&T Senior
I heard that they were doing a 3 wheeled linear shooter. Was hoping that they might have done some wheel prototyping. Alas, luck was not on my side again.
Unread 07-02-2013, 12:51
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
We (2826) tested all three different wheels from banebots and saw no difference in distance. The only difference was the wear of the wheel, the blue wheels last well over 20 times longer in our tests than wither the green or orange wheels....
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-2016 Wave Robotics Team 2826
