Go to Post ... as teammates we often get too into the craze of competition and forget that this wouldn't happen without so many dedicated people. - miketwalker [more]
Unread 06-02-2013, 23:32
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: 3992 Drive Train
Originally Posted by ksafin View Post
We had the previous drivetrain (the 80/20 one) driven, and it seemed to be fine.
I'm not particularly sure what the software team did, its possible that they set a cap on the motor output speed (such as setting 75% as a max for the motor controllers).
If so, you are limiting the torque you are getting. This *shouldn't* be bad for mecanums, as I assume you won't be in pushing matches, but it really hurts your acceleration.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 06-02-2013, 23:34
akoscielski3's Avatar
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
The speed you have on your speed controller's will never help you with torque. You WILL NOT have enough torque to turn your wheels, and decreasing the current won't help that. You need to change your gearing. Have you tested your drive train? If not I would HIGHLY suggest it.
My team had direct driven Macanum's (6in from CIMple boxes) in 2011 and we could only drive forward/backwards and turn, we couldn't strafe because we didn't have enough torque to turn the wheel opposite to eachother. PLEASE CHECK YOUR DRIVE NOW!!! Before it's too late and you're a sitting potato on the field.
2013-Present
Team 772 Sabre Bytes
2010-2013
Unread 06-02-2013, 23:44
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
What do you characterize as not being able to strafe?
Did you not have enough torque to strafe period?
When we tested this on the previous drivetrain, it succesfully strafed, albeit it a slight angle rather than directly perpendicular.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 06-02-2013, 23:46
it would attempt to strafe, and would kinda move, but not really.
There was not enough reduction, usually people would use toughboxes on macanum's we were dumb and didn't
did you have 150lbs on that robot? that's when you need to the torque.
2013-Present
2010-2013
Unread 06-02-2013, 23:55
ksafin's Avatar
AKA: Kirill Safin
What about putting a Mini-CIM in each gearbox for additional torque? Or RS-775's on CIM-U-Lators?
Unread 07-02-2013, 00:01
Gregor's Avatar
Thats not a bad idea, and probably the fastest switch, but switching to Toughbox Mini's would give you the best results.
<Since 2011
Unread 07-02-2013, 00:10
ksafin's Avatar
AKA: Kirill Safin
We'll see what we can do.
We'll test with this and a heavy load on the chassis and see if the results are poor enough to warrant the switch.
If anything, I think we'll switch to toughbox Nanos. The mini has a front plate bigger than our actual plate so it'd be an odd fit.
Unread 07-02-2013, 00:12
Gregor's Avatar
TB Nanos are also a good choice, I like them.
<Since 2011
Unread 07-02-2013, 09:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
But I can say for sure that it was nowhere near 30 fps.
The reason it's nowhere near 30fps is because you're pushing your motors way closer to stall than an average drivetrain. They aren't going to come anywhere near the free speed, yet they'll draw more current than a properly geared drivetrain and will accelerate much slower.
Unread 07-02-2013, 13:19
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
I'm going to quote my post in the other thread you posted with your practice robot.
Have you actually driven this yet? It is far too fast.
I doubt that they will realistically achieve this kind of speed with the losses in the gearbox, lack of friction with the carpet, and other losses. If they do in fact reach speeds comparable to 30 fps then more power to them. This years game has no mid-field obstacle and score will be determined heavily by how fast disks can be ferried from the feeder station to shooting position. A fast drive base could be a game changer.
Unread 07-02-2013, 21:30
Gregor's Avatar
This is true, all the more reason to use a greater reduction. Lets say they never surpass 18 ft/s when geared for 30 ft/s (random guess). If they gear for 18 ft/s, you get the same top speed with greater acceleration and torque.
<Since 2011
