Go to Post Because of the silly "What's the best 254 team" thread I recently found there is an Electric Sheep! 2546. TBA also says 2505 is The Electric Sheep But which team is the one androids dream of? - Katie_UPS [more]
Unread 09-02-2013, 18:37
couvillion couvillion is offline
FRC #1818
couvillion is an unknown quantity at this point
pic: On board voltmeter
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: pic: On board voltmeter
Cool! Is it legal?
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 09-02-2013, 18:47
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Not in that configuration. An inspector is never going to pass that 24 gauge wire being protected by a 40A breaker. Switch it over to on of the smaller terminals and plug in a 20A (but preferably 5A) circuit breaker, and THEN it will be legal. It's just a custom circuit, after all.
Unread 09-02-2013, 19:23
FRC #1818
It's purpose though is mainly debugging before you get to the field. When the robot doesn't work there is a tendency to stare at it while the kids wiggle the controls. Now a little bit of insight might be gain, while scratching at the beard.
Unread 09-02-2013, 19:28
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I had a similar idea this summer.
I was planning to put one of these on our robot but I couldn't find a purple 7 segment LED to replace the green ones with. I might get one any way.
Unread 09-02-2013, 19:48
I'll just leave this here...
Three Digit Purple 0.56 Inch (14.20mm) LED Display Anode
0.56 Inch (14.20mm) Three Digit LED Display - Purple (Cathode)
You get to figure out if it's worth having 9 extra displays. And whether you need common cathode or common anode.
Unread 10-02-2013, 02:40
Engineering Coach
9 extra? Those are just the ones for our next 9 robots. Thanks Kevin.
Unread 10-02-2013, 10:19
I'm guessing you just looked on Mouser and Digikey and such, because I just Googled "purple seven segment".
For anyone else interested in customizing their voltmeter, LC LED offers the 3 digit display red, green, orange, blue, yellow, purple, and white. Only trick is that you have to order a "sample" of 10 displays for $29.80. So if you're looking for a more common color, Mouser or Digikey is probably an easier solution.
