Go to Post Some people need the 2x4. - Ether [more]
Unread 10-02-2013, 19:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
pic: 57 Five Weeks In
Unread 10-02-2013, 19:54
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: pic: 57 Five Weeks In
Kevin,
Does you shooter change angle? Also I'm excited to have 57 at the Week 0 next week, please try to make it.
Allen
Unread 10-02-2013, 19:55
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Kevin,
Allen
It seems as though it does change angle as you can se pneumatic pistons bellow it
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 10-02-2013, 19:57
Engineering Coach
The two on the sides look to be for hanging unless they do both. I think there is a center post that might tilt it but it's hard to see in that picture.
Looks simple and effective.
Any reason why those 10 point hanging hooks aren't completely passive? Could save yourself a little weight and time at the end of a match that way, though I am sure your solution is already fast (and it's a buzzer beater).
Unread 10-02-2013, 20:23
The center post is indeed the angle changer. There's a 20:1 BAG versa at the base attached to a 1/2" 0.25 lead screw. Yeah, the 1/2" screw is a bit overkill, but we already had it and the nut in the shop.
We're planning on shooting either from the far side or near side of the pyramid. For ranging and alignment we want to just run into the pyramid. A passive hanging system wouldn't have allowed that. If the active system gives us any problems we'll just bolt a passive hanger on.
The simplicity is thanks to designing and building within means. We graduated a lot of experienced seniors and had a lot of new students and mentors this year. Plus a lead mentor with a lot more time constraints due to a new son. So said lead mentor put some limits on what we could practically accomplish in our 6 weeks. As a result we're going to finish with time to spare for practice this year.
Unread 10-02-2013, 21:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That's a nice clean design. I like how spacious it is. I almost wish we hadn't had a 30" height restriction built in to our initial specifications, since it made finding room for all the electronics a bit of a challenge.
No floor loading? I wonder how many teams will make that decision work well, and how many will have problems with a floor-pickup-only design.
I do worry about the placement of your D-Link, though. It's awfully close to that last shooter motor, and potential interference is an issue.
Unread 10-02-2013, 21:20
Floor loading wasn't in the cards. If we added that system, we'd likely be wiring and programming in Week 7.
As for the radio, we can move it to the other side if it becomes a problem. You didn't see electrical's previous proposals which included buried in the nest of the main electrical board and just above the three Jags for the shooter.
Unread 11-02-2013, 07:41
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
What? No ramps this year? I thought that was a Leopard tradition...
Unread 11-02-2013, 09:05
I suggested it in brainstorming, but then people threw things at me. Apparently there ARE bad ideas in brainstorming.
Unread 11-02-2013, 11:05
Pjohn1959's Avatar
LOL!
Unread 11-02-2013, 13:28
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
I'm really excited to hang out with 57 at the Week 0 scrimmage this weekend !
The design looks simple and effective !
I spy a lowe's bucket under those leopard spots, we stuck with a home depot bucket for a while and eventually moved on to clear plastic sheet that works really well.
We went with a week 7 collector design that is still in the works ! So I can understand your decision in keeping things simple,
My first robot scrimmage was in high school at 57's shop in Houston, times have changed
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 11-02-2013, 17:13
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Looks nice Kevin. Sure wish you guys were coming to Bayou again this year. It's hard to tell looking at the photo but are you sure your CRIO is isolated from the chassis? It sort of looks like it is bolted right to the metal bar. If so you might want to double check you don't have a chassis short to ground.
Unread 11-02-2013, 17:44
It's actually mounted on that Lexan, but I'll admit I wasn't looking close at the back side when they mounted the whole electronics board to the robot. I'll electronics check that and work out a fix if it's making contact or risking doing so. Thanks for the catch.
EDIT:I'm assured it's an optical illusion caused by the angle I shot the picture from. The lexan sheet is a good inch or more away from that bar.
