Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 12-02-2013, 12:46
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Re: pic: 3997 Screaming Chickens Robot
Originally Posted by lynca View Post
Interesting setup !
what levels and how long does it take to climb?
Its a welded together steel hook on a round stock slider. It runs on a 2 inch bore; 12 inch stoke cylinder. It goes up in a couple of seconds when pressure is at full.
If your talking about the setup you see in the pic. Its the same setup just run directly off a cim and all thread. If the motor is cool it would take 3 seconds to climb but after the first time it would pop breakers. So we decided to change to a pneumatic cylinder which work alot better for us.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
