Re: pic: Our Big Drill Press
When you have time, figure out the kWHr per hole. Kinda like the gallons/mile computations for ocean liners.
The motor is rated at 600V 15A That's 9kw 25% of 9kw is 2.25kw 30 seconds is approximately 0.00833 of an hour. 2.25kw * 0.00833 = 0.0187425 kWHr per hole or ~18.75 watt hours per hole. by that math 3 holes uses the same amount of power as it takes to run an 60w lightbulb for a hour. - Adam |
You should change that 60w bulb to a FIRST e-watt LED.
