Go to Post Adding more weight doesn't make the challenge any easier, it just makes the robots heavier. - Sean Schuff [more]
Unread 14-02-2013, 11:50
4057programmer 4057programmer is offline
FRC #4057
4057programmer is an unknown quantity at this point
pic: FRC team 4057 completed robot
Unread 14-02-2013, 11:54
cbale2000's Avatar
AKA: Chris Bale
FRC #5712 (Gray Matter)
Re: pic: FRC team 4057 completed robot
So are you planning on scoring goals from the feeder station? If so, how are you accounting for the angle of the feeder station relative to the position of the goals (since they don't line up)?
Either way, it would be a pretty neat design if you could make full-court shots from the feeder station.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 14-02-2013, 12:08
DMike
Looks Great, glad to see another second year team toughed it out. An accurate (80-90%) full court shooter would be great, I agree. How do you plan on negotiated the distribution of frisbee's with the rest of your alliance? You may end up with 2 or three other non-retrieving shooters on you alliance. Would loading at the feeder and moving to a more accurate shooter location be more efficient scoring method if 2-3 of you team mates were doing the same thing? 4134 has been kicking around a lot of ideas , we can shot full court at 50-80 % in the 2 point goal, but 80-100% from the pyramid in the 3 point goal. We have no retriever , but have a reliable 10 point hanger.
Unread 14-02-2013, 22:39
FRC #4057
we accounted for the angle by angling our shooter. the end has a bend in it, but I don't remember the angle we set it to off hand though. With the ability to adjust the angle of our shooter we will also be a dynamic team able to move and score from multiple locations. Thanks to our team getting done with this a week early we have had some great time to test this out and find our sweet spots to shoot from. the Possibility of scoring in the top pyramid goal has also come up and it looks like it could be a possibility. Fingers crossed for that!
Team 4057: Autodesk regional Rookie All-stars!
If it's not on fire, its programming. If it compiles, it's electrical
Unread 14-02-2013, 22:42
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
What do you weigh in at?
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 14-02-2013, 23:49
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Any chance of adding a ten point passive hanger?
-Plutarch
Unread 15-02-2013, 02:06
FRC #4057
we are working on the 10 point hang. don;t know if we can fit a passive hang or not though. and we clock in at a staggering 88.5 pounds. blew us away how light we were. just means we get 30 pounds of dead weight to offset the shooter for driving.
Unread 15-02-2013, 02:07
FRC #4057
but if things work out. we can score the pyramid goals, meaning we could wait for the last 20 seconds or so and instead of climb take a few more shots and maybe make 20 instead of 10 points.
Unread 15-02-2013, 03:37
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
you can score the colored frisbees into the pyramid goal at any time during the match though... so you could score them at the beginning of the match if you wanted, and then hang at the end.
Unread 19-02-2013, 01:01
FRC #4057
Here is a link to this shooter in action:
http://www.youtube.com/watch?v=cNNyV...ature=youtu.be
This is in our school's hallway, but we have many witnesses to this shooter in action at a scrimmage put on in corvallis. We have a reliable 18 point autonomous mode working as well. This is just a simple demo of our reliability to shoot full court into the 2 point bin.
