Go to Post FIRST isn't about the money. It is about the experience. - dubious elise [more]
Unread 01-23-2003, 10:56 AM
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: 116 - Teaser #1
Unread 01-23-2003, 10:57 AM
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
sure looks like a piston driven engine to me
Unread 01-23-2003, 12:44 PM
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Looks more like a walking mechanism to me
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 01-23-2003, 03:10 PM
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
if i didn't know better, i'd say an internal combustion engine, but that's not FIRST legal, is it...?
AIM --> Woloi
Email --> ian@woloschin.com
Unread 01-23-2003, 11:25 PM
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
It looks like a pneumatically-driven engine... I see cylinders in there.
Won't go fast enough to go anywhere. Monster torque though. Probabaly burn up the compressor in the process.
Ingenious design though. Good job.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 01-23-2003, 11:38 PM
College? What?
one thing we may be ignoring...
Description:
A little hint of what we are developing.
It is always best to plan for the future by learning from the past.
i wonder if that means they randomly found some picture online, which represents something that they are doing? i just have a tiny feeling that a pneumatically driven drive train won't cut it this year. and seeing as internal combustion is illegal, i would go with this is meant to completely throw us off, or just represent something that 116 is working on.
now that we might know a bit more, any ideas of what that monstrosity might represent?
AIM --> Woloi
Unread 01-24-2003, 12:02 AM
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
If its pneumatic its a waste. Why put all that energy into a motor(compressor), then convert it into pressure, then into rotary motion when you could of just used a motor?
My guess is its a vacuum generator.
Unread 01-24-2003, 01:26 AM
Go Badgers!
#0093
Because 2" cylinders generate 180lbs of force... you're talking about a lot of torque. However, you wouldn't be able to switch them fast enough to generate a descent speed. You could gear it up and still have plenty of torque to push people around. It's just not worth the strain on the compressor. They burn up rather easily. Get a back-to-back match and you're toast.
Vacuum generator is another possibility. If you drive the shaft, the cylinders would depressurize. However, the shaft doesn't go for the entire stroke length of the cylinder, so you can't generate a descent vacuum.
Unread 01-25-2003, 03:17 AM
sevisehda's Avatar
Depending on the length of the cylinders and the size of the cams they could go the full length. It would help to know if the cutouts are visual or actually there.
Unread 01-26-2003, 10:03 PM
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
That would be amazing to actually see a team run off of a pneumatic engine. The power would probably be insane, there wouldn't be much that could stop it. Unless you wait for the compressor to explode ofcourse.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
pic: 111 Teaser (tiny teaser) CD47-Bot Robot Showcase 15 03-04-2003 12:49 AM
Image Discuss: 294 teaser, what's that? CD47-Bot Robot Showcase 4 02-20-2003 12:09 AM
Image Discuss: Team 45 Teaser 2 CD47-Bot Robot Showcase 6 02-05-2003 04:54 PM
Image Discuss: 294 teaser, what's odd? CD47-Bot Extra Discussion 3 02-03-2003 12:06 AM
Image Discuss: MVRT 115 Teaser 1 CD47-Bot Extra Discussion 2 02-02-2003 10:19 PM
