Image Discuss: 116 - Teaser #1
sure looks like a piston driven engine to me
Looks more like a walking mechanism to me
if i didn't know better, i'd say an internal combustion engine, but that's not FIRST legal, is it...?
It looks like a pneumatically-driven engine... I see cylinders in there.
Won't go fast enough to go anywhere. Monster torque though. Probabaly burn up the compressor in the process. Ingenious design though. Good job. Last edited by Jnadke : 01-23-2003 at 11:28 PM. |
one thing we may be ignoring...
now that we might know a bit more, any ideas of what that monstrosity might represent? ![]() |
If its pneumatic its a waste. Why put all that energy into a motor(compressor), then convert it into pressure, then into rotary motion when you could of just used a motor?
My guess is its a vacuum generator. |
Because 2" cylinders generate 180lbs of force... you're talking about a lot of torque. However, you wouldn't be able to switch them fast enough to generate a descent speed. You could gear it up and still have plenty of torque to push people around. It's just not worth the strain on the compressor. They burn up rather easily. Get a back-to-back match and you're toast. Vacuum generator is another possibility. If you drive the shaft, the cylinders would depressurize. However, the shaft doesn't go for the entire stroke length of the cylinder, so you can't generate a descent vacuum. Last edited by Jnadke : 01-24-2003 at 01:33 AM. |
Depending on the length of the cylinders and the size of the cams they could go the full length. It would help to know if the cutouts are visual or actually there.
#10
That would be amazing to actually see a team run off of a pneumatic engine. The power would probably be insane, there wouldn't be much that could stop it. Unless you wait for the compressor to explode ofcourse.
| pic: 111 Teaser (tiny teaser) | CD47-Bot | Robot Showcase | 15 | 03-04-2003 12:49 AM |
| Image Discuss: 294 teaser, what's that? | CD47-Bot | Robot Showcase | 4 | 02-20-2003 12:09 AM |
| Image Discuss: Team 45 Teaser 2 | CD47-Bot | Robot Showcase | 6 | 02-05-2003 04:54 PM |
| Image Discuss: 294 teaser, what's odd? | CD47-Bot | Extra Discussion | 3 | 02-03-2003 12:06 AM |
| Image Discuss: MVRT 115 Teaser 1 | CD47-Bot | Extra Discussion | 2 | 02-02-2003 10:19 PM |
