Go to Post If you guys ever need anything, just let us know. Just remember you have the FIRST family behind you.<3 - hayleybayley217 [more]
Unread 19-02-2013, 21:58
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: VeraPlanetary Motor Centering Ring
Unread 19-02-2013, 22:00
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: pic: VeraPlanetary Motor Centering Ring
That a neat idea. Did you follow the mounting directions on the VEX website? Once we learned the proper mounting instructions we have our gearboxes spinning much smoother.
Unread 19-02-2013, 22:09
Bob Steele's Avatar
Professional Steamacrit Hunter
AKA: Bob Steele
We just designed and fabricated our own plates to match the motor we were using... in our case... we designed a thicker plate with the correct size opening for the AM motor... a thinner plate matching the ones that came with the gearboxes with the correct size holes for both the bag motor and the banebot 550 motor....
We didn't like using the little spacers for the AM motor... and wanted to make changes quickly in the pits for the other motors...
These worked fine... we waterjetted them and they really help in a quick change of motors... We have extra plates with new motors that can be easily switched out.
One word of warning for everyone using those gear boxes... Please use locktite on those set screws... they have a habit of working loose...we have seen this several times on prototypes...
Nice, versatile little gearboxes....
Unread 20-02-2013, 09:49
Allen, we wound up having to do something very similar. Even when we'd follow the website instructions, if the motor plate was mounted even slightly off-center to the plate the entire gearbox would bind no matter how many times we loosened/retightened a quarter-turn. Ours still aren't perfect (but they're much better) because we don't have metric drill bits.
GitHub
Unread 20-02-2013, 22:07
JJackson's Avatar
JJackson JJackson is offline
FRC #0781 (Kinetic Knights)
JJackson is an unknown quantity at this point
We've been using fibre washers to line ours up.... we also made up a spacing tool
Unread 20-02-2013, 22:56
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Great modification! I think we'll be using this trick in the future, since we also had difficulty getting the motors to be concentric. Thanks for the idea!
