Go to Post Regardless on how you feel about any team--respect should be paramount. - MeGuttieri [more]
Unread 23-02-2013, 22:31
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Power distribution board problems
On the other hand, if faulty wiring is to blame, you might just fry every sidecar you install before you find the real problem. And since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting.
